1991 Chrysler Le Baron
BRENDAN.H
1991 Chrysler Le Baron 6 cyl 88,000 miles
Turn signals dont work the only way that the turn signals work is if i hold the switch down with the high beams on.
Mar 13, 2010 at 6:40 AM
LEGITIMATE007
  • 5,121 POSTS
change the flasher fuse for the turn signals. I believe chrysler uses the rectangular fuses, either black or yellow, located in the fuse box, on drivers side
Mar 13, 2010 at 12:33 PM
