1990 Chrysler Le Baron signal light flasher
95,000 MILES • 6 CYL • FWD • AUTOMATIC
KARLI2007
i cant seem to find where to replace the signal light flasher
my manual says under the fuse box but i cant find it please advise thanks
Jan 25, 2010 at 12:50 PM
BLUELIGHTNIN6
  • 16,542 POSTS
You will find the turn signal flasher in the front seating area, driver side, driver side of steering column, under dash, mounted above fuse panel
Jan 25, 2010 at 12:54 PM
