1990 Chrysler Le Baron driving belt
113,000 MILES • 6 CYL • FWD • AUTOMATIC
THEBRYGUY60
I took off the driving belt on my 1990 lebaron to remove the alternator to get it tested now i can not seem to get the belt back on, i have loosened the tension arm and put the belt back on all the pullys but i can get the tension arm back into place the pin is like a centemeter from going in but i am still unable to get it to that point...is there anything else i can do?
Mar 2, 2008 at 1:02 PM
SERVICE WRITER
  • 9,123 POSTS
Double check the diagram for routing. If the belt tensioner is not moving free, replace it. IT was probaly seized when you moved it.
https://images.2carpros.com/forum/automotive_pictures/30961_abelt_1.jpg
Mar 2, 2008 at 2:00 PM
