1990 Chrysler Le Baron
CUDDLES789
  • 1990 CHRYSLER LE BARON
Transmission problem
1990 Chrysler Le Baron 4 cyl
i need to know if I can drain my transmisiion by myself because I put 1 litre of oil in it last nite and I put the trans fluild in my oil I need to know if itll be easy
Saturday, January 30th, 2010 AT 7:41 PM
  • 109,755 POSTS
TO drain the trans fluid, you need to remove the trans pan. However, if you ran that car like that, the oil will be throughout the trans including the torque converter and will not be drained when you remove the pan. In that case, have a power flush done on the transmission.
I also recommend servicing the engine too.
Thursday, March 11th, 2010 AT 10:26 AM
