1989 Chrysler Lebaron Leaking oil.
SMOOCHES_BABE
  • 1989 CHRYSLER LE BARON
My 1989 Chrysler Lebaron is leaking alot of oil. I put about two quartz in it every two days. It just started doing this after I got the oil changed in it. What do you think mibht be wrong with it, and how much do you think it will cost?
Sunday, August 12th, 2007 AT 11:03 AM
CANADIANAPPRENTICE
  • 18 POSTS
Where is the leak, the V6 model's are notorious for leaking. "We refer to them as bleeding 3's"
locations of leak.
---> Oil filter loose or double gasketted
---> valve cover seals
---> Rear main seal- between motor and trans
---> Camseals right on the top of the motor.
---> into the motor via valve seat seals.
If there is alot of carbon deposits on your tailpipe, your burning oil, considerable amounts.
Monday, August 27th, 2007 AT 8:15 PM
