1989 Chrysler Le Baron squeak Belt
92,000 MILES • 4 CYL • FWD • AUTOMATIC
ROUSTABOUT
I have a 1989 Lebaron GTS with a 2.5.
It has 3 belts 2 V belts and one Serpentine Belt.
after removeing the 2 V belts I knew It was the Serpentine Belt. I replaced the Serpentine Belt saturday
I was quite for about 70 miles. On sunday the squeak was coming back back.
Today I removed the V belts and the Squeak is the Serpentine Belt as before. what Can I do?
Aug 25, 2008 at 5:48 AM
  • 110,246 POSTS
Hi:
Is the tensioner good? If it's not placing enough tension on the belt, that can happen. Also, is there oil, coolant, or any contamination on the belt?
Oct 23, 2008 at 1:47 AM
