1988 Chrysler Le Baron Trunk
1988 CHRYSLER LE BARON
TOPHER13
1988 Chrysler Le Baron 4 cyl Front Wheel Drive Automatic
I can not get into the trunk of my Le Baron. The key will not turn and the lever inside the car will not open it. I tried putting WD-40 in the key hole to losen up any tumblers with no luck.
Aug 1, 2010 at 7:59 AM
BLUELIGHTNIN6
  • 16,542 POSTS
if the trunk is locked and key not turning than you can either try new key or if that doesn't work you may have to drill out the lock cylinder to get into the trunk and then of course replace the lock cylinder.
Oct 21, 2010 at 4:01 PM
