1988 Chrysler Le Baron Power door lock relay
LIONELCGZ
  • 25 POSTS
Electrical problem
1988 Chrysler Le Baron 4 cyl Front Wheel Drive Automatic
Hello.
Do you know were are located the power door relay on a 1988 Chrysler Lebaron 2.2L turbo coupe ?
Jun 8, 2009 at 10:08 AM
  • 75,988 POSTS
C/B no.8 30amp powers the door lock system Its in the fuse block called circuit breaker check no.8 30amp breaker.
https://images.2carpros.com/forum/automotive_pictures/12900_door_lock_system_1.jpg
Jun 8, 2009 at 10:37 AM
LIONELCGZ
  • 25 POSTS
Hello.
Thank you for your quick answer.
You are talking about the fuse in the fuse box, but not the relay who are not in the fuse box at the right place under the steering wheel column.
Thank you also for the diagram, but it's too small and i can't read it.
Would you please check again for the place of the power door lock relay place.
Is it possible that you send me the diagram to lionelcgz@free.fr
Thank you very much.
Jun 8, 2009 at 4:28 PM
  • 75,988 POSTS
I've checked for the relay but there's non listing for your vehicle only the circuit breaker
https://images.2carpros.com/forum/automotive_pictures/12900_dl1_1.jpg
https://images.2carpros.com/forum/automotive_pictures/12900_dl2_1.jpg
https://images.2carpros.com/forum/automotive_pictures/12900_dl3_1.jpg
Jun 8, 2009 at 6:03 PM
LIONELCGZ
  • 25 POSTS
Thank you for that. That helps me a lot.
You are right, there are no relay. The switch are the relay.
Now, may i ask you if you have the electrical diagram for the headlights switch and for the relay who command the lights, headlights and headlights covers (placed on the top of the dashboard).
Thank you a lot.
Jun 16, 2009 at 8:31 AM
