1988 Chrysler Le Baron My Brakes are not working
117,000 MILES • 4 CYL • FWD • AUTOMATIC
RAYNADARIUS
I have bled my brakes over and over and still i have no brakes. What is my problem?
Oct 11, 2009 at 10:34 AM
  • 75,988 POSTS
If its not leaking anywhere if it was me I'll start by replacing the brake master cylinder then rebleed the system
Oct 11, 2009 at 10:40 AM
RAYNADARIUS
[quote:61696e40d4="rasmataz"]If its not leaking anywhere if it was me I'll start by replacing the brake master cylinder then rebleed the system[/quote:61696e40d4]
I will go n buy the piece n i really appreciate the feedback
Oct 12, 2009 at 1:44 AM
RAYNADARIUS
I have replaced the master cylinder. I still have no brakes and no pressure. What else can be the problem? Also i think my rear cylinder has a small leak because when i took the tire off the rim had brake fluid on it. But i cant change it because it is so rusted on.
Oct 16, 2009 at 5:43 AM
