1988 Chrysler Le Baron ignition switch
EYBERGD
1988 Chrysler Le Baron Two Wheel Drive Automatic
I am unable to turn ignition with current key and switch, I have a new ignition switch/key, but how do I get the column cover off and old ignition out??
Dec 29, 2008 at 2:13 AM
  • 110,248 POSTS
Hi:
You need to remove the steering wheel and part of the steering column to access the switch. Because of the air bag, I would recommend having it done by a trained tech. If you do it, be careful and make sure that you leave the battery disconnected for at least 15 minutes before starting the work.
Mar 17, 2009 at 3:26 AM
