The drivers side shaft is held to the side gear with a spring c-clip, if the support bearing that the shaft slides into (and i'm betting on this) has a rough ball bearing it will pop the shaft out again. It is not to difficult to replace the output shaft bearing and available aftermarket
Saturday, July 28th, 2007 AT 11:58 PM
