1987 Chrysler Le Baron fuel pump
93,335 MILES • 4 CYL • FWD • AUTOMATIC
BISH23
I need to know where the fuel pump is located on this vehcile so that i can change it. thank you
Sep 26, 2008 at 10:35 AM
OBXAUTOMEDIC
  • 3,711 POSTS
[quote:9dfb514a8e="bish23"]Engine Performance problem
1987 Chrysler Le Baron 4 cyl Front Wheel Drive Automatic 93335 miles
I need to know where the fuel pump is located on this vehcile so that i can change it. thank you[/quote:9dfb514a8e]
If it is fuel injected the pump is in the gas tank.
Sep 26, 2008 at 11:00 AM
