1987 Chrysler Le Baron can not get fire to coil
GCAM09
Electrical problem
1987 Chrysler Le Baron 4 cyl Front Wheel Drive Automatic
my 1987 chrysler le baron engine turns over but will not start.the coil is getting no fire.i have replaced both the pcm and the lcm but still doing same thing.any suggestions would really be helpful thanks.
Jul 20, 2010 at 5:07 AM
  • 75,988 POSTS
No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it.
Jul 20, 2010 at 10:32 PM
