1985 Chrysler Le Baron WON'T START
87,500 MILES • 4 CYL • FWD • AUTOMATIC
WMCDADE1
I HAVE A 2.2 LTR TURBO POWER LOSS LIGHT ON. CODE IS #54. CAR JUSTS QUITS RUNNING. REPLACED HULL SENSOR. AFTER IT QUITS WILL NOT START AND POWER LOSS LIGHT DOES NOT ILUMINATE WHEN KEY IS TURNED ON. SWAPPED OUT LOGIC MODULE AND SAME RESULT. NO SPARK FROM COIL WHICH IS 2 YRS OLD.
Jul 26, 2008 at 3:11 PM
  • 110,248 POSTS
Hi:
Do you have power to the coil?
Oct 4, 2008 at 4:18 PM
WMCDADE1
No power to the coil
May 26, 2009 at 3:05 PM
  • 110,248 POSTS
Make sure the wiring harness is tight in the computer. If it is, check for a damaged power supply wire. If they are all ok, you will need to have the computer tested.
May 27, 2009 at 12:00 AM
