1984 Chrysler Le Baron IDLES TOO HIGH
32,000 MILES • 4 CYL • FWD • AUTOMATIC
DANYELL
WHAT CAUSES HIGH IDLING. WHEN I CRANK THE CAR IT IDLES FINE THEN TOO HIGH. WHAT COULD CAUSE THAT. IVE CHANGED THE PLUGS AND WIRES PUT IN SOME INJECTOR CLEANER AND IT STILL DOES IT. IVE CHECKED FOR HOSE LEAKS OR DAMAGED HOSES NOTHING. COULDNT FIND THE IAC VALVE. HELP PLEASE.
Oct 23, 2010 at 12:59 PM
BILLYMAC
  • 2,204 POSTS
check the intake manafold for leaks. the iac is bolted on the throttlebody near where the accell cable connects
Oct 26, 2010 at 8:02 AM
