1982 Chrysler Le Baron Fuel Pump
78,000 MILES • 4 CYL • 2WD • AUTOMATIC
ZACARIASA
The engine of my car quit working. After troubleshooting, I find out a problem with the fuel pump. I replaced it. Three week later the pump fault it again. Do you know a reason why the fuel pump is damaged in my car very often? I will appreciated any support.
Thanks
Alex
Sep 29, 2008 at 5:04 AM
  • 110,248 POSTS
Hi Alex:
If you purchased an aftermarket fuel pump. this isn't unusual. Some of the lower end parts from discount part stores are poorly built and fail. My recommendation is to get your money back on the bad pump, and replace it with a factory pump. It may cost a little more, but I feel confident that it will last much longer.
If you have any specific questions, let me know.
Oct 4, 2008 at 3:47 PM
