1986 Chrysler Laser headlights
PUCK68
Electrical problem
1986 Chrysler Laser 4 cyl Front Wheel Drive Automatic
headlights wont work unless you hold the dimmer switch. We replaced the headlight switch and still the same thing. any suggestions?
Aug 29, 2009 at 5:27 PM
CH112063
  • 1,320 POSTS
Many times two headlamps are burned out or the dimmer switch is bad. After that is wiring, connector or(if concealed headlamps) headlamp motor and connector is another possibility. The best way to test is actually a 12 volt test lamp or ohmmeter.
Sep 13, 2009 at 1:12 PM
