2004 Chrysler Intrepid Engine Light On - Accelerated Too Fa
2004 CHRYSLER INTREPID
EDGE16
While leaving work today i accelerated too fast and RPMs went to about 6000. While this happened, the speedometer needle dropped to 0 then back up to speed. The car continued to drive but it kept jerking back and forth and the engine light came on. I pulled over, turned off my car, then turned it back on. I continued driving home and all seemed fine although the engine light was on. I'm worried that it could be something serious. Any ideas?
Jan 23, 2010 at 11:14 AM
Have the computer scanned for code/s-you have a problem within the engine manangement system that caused the CEL to turn on-This is your starting point of diagnosis,finding out what's going on.
Jan 23, 2010 at 12:35 PM
EDGE16
Several people suggested that it might be a blown head gasket but there is no sign of anti-freeze in my oil so I'm not sure. I may just need to bring it to a shop and get it checked out.
Jan 23, 2010 at 3:26 PM
At no time you've mentioned overheating but if it is get it block and pressue tested to rule out the headgasket and cracked head or block
Jan 23, 2010 at 4:52 PM
