2002 Chrysler Intrepid Water Pump
80,000 MILES • 6 CYL • FWD • AUTOMATIC
BHOWCROFT
Over the past 2 yrs I have had the water pump replaced or in the last case the housing was replaced. Each time I have had the same issue, leaking of green fluid on my garage floor and each time this has lead to costly repairs. Any idea what the mechanic could be missing here?
Mar 4, 2009 at 1:59 AM
  • 110,251 POSTS
Have him make sure the housing isn't warped. Also, all of the old gasket material needs to be removed, the parts need to be clean and dry when replaced. Also, is he using gaskets for the repair or form-a-gasket sealent?
Mar 16, 2009 at 3:25 PM
