2000 Chrysler Intrepid
POTAN2009
Transmission problem
2000 Chrysler Intrepid 6 cyl Front Wheel Drive Automatic
What can i do to fix my transmission problem?
Alot of codes came up,Input/Turbine speed Sensor Circuit Malfunction. Transmission Control System Manfunction. Gear 1,3,4 Incorrect ratios and CAT,02, and EGR codes came up. Can you help ?
thanks
Oct 4, 2009 at 12:18 PM
BMRFIXIT
  • 19,053 POSTS
Check fuses
check relays
remove connectors and check pins (ON TCM AND TRANNY side too)
reset codes and try again
Oct 4, 2009 at 12:31 PM
