2000 Chrysler Intrepid
88,000 MILES • 6 CYL • FWD • AUTOMATIC
NATBUG1211
my car died for not reason i replaced the main computer and the fuel rail fuel pressue regulator and intake manifold and spak plugs what could it be and i got a code but is it for the new or old computer. p0340
Apr 27, 2009 at 3:29 PM
JDL
  • 16,098 POSTS
Hello, did you do any testing before you replaced anything? The code was for cam sensor circuit. The crank and cam sensor share ground and ref voltage circuits. A circuit problem could effect both or either.
With the engine cranking, do you have spark at the plugs--injector pulse?
Apr 27, 2009 at 4:01 PM
