2000 Chrysler Intrepid
176,000 MILES • 6 CYL • FWD • AUTOMATIC
MARY.JOST
my 2000 chrysler intrepid the car over heated and went into auto autoshut down how can i restart the car is gettin spart and fuel but will not start would this issue have anything to do with the auto shutdown relay
Apr 27, 2009 at 12:44 PM
  • 110,248 POSTS
If you are getting spark and fuel, it's not the auto shutdown. I would recommend doing an engine compression test to see if you blew a head gasket. If you have spark, fuel, and compression, it should run.
Here is a how to for checking compression:
https://www.2carpros.com/dia/how_to_check_compression.htm
Let me know what you find.
Aug 8, 2009 at 1:41 PM
