1999 Chrysler Intrepid Fuel system
1999 CHRYSLER INTREPID
240,000 MILES • 6 CYL • FWD • AUTOMATIC
KROETSCH123456
My car is a 2.7 liter.It will start and drive different distances each time it does actually start.Sometimes I can hear the fuel pump activate when I turn the key,then it will start.Then other times I cant hear it activate then it obviously doesnt start.It never makes it very far even when it does start.Now in obvious thought a guy would think it was simply the fuel pump?But ive had people tell me when a pump dies its simply done and wont continue on teasing you by working sometimes.It seems to stop running after the car is warmed up and driving a little while.Although sometimes after it sits for along time,it still wont start.A friend suggested it was the camshaft sensor.I bought a new one and put it in.Same thing happened.Then someone suggested it could be the crankshaft sensor?Im done doing things to just spend money with no results.Could it be the fuel pump?And would it still work for short distances then quit again?
Dec 5, 2009 at 4:58 PM
Next time you go inside and will not start -do below this might just lead you somewhere if its fuel or spark issue
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it
_________________
Dec 5, 2009 at 7:28 PM
KROETSCH123456
My mechanic did a fuel pressure test on it and it came up very good.
Dec 6, 2009 at 8:10 PM
Dunno the fuel pressure readings but if its within specs-check for injection pulses and for spark if engine compression is good
Dec 7, 2009 at 5:18 AM
