1999 Chrysler Intrepid front strut replacement
1999 CHRYSLER INTREPID
81,000 MILES • 6 CYL • FWD • AUTOMATIC
CHUCK1974
Would I have to have my car realigned if I replace my front struts myself? I am assuming I would not because my manual says nothing about loosing the adjuster sleeves on the tie rods. Can anybody help me?
Nov 18, 2009 at 11:14 AM
OBXAUTOMEDIC
  • 3,711 POSTS
Yes you will need a front end alignment. You won't be messing with the toe in and out but you will be messing with the Camber/Caster alignment.
Nov 18, 2009 at 11:40 AM
CHUCK1974
Thank you for your input. I will not be trying replacement on my own. Not confident enough with removing springs, etc. Sears Auto gives free install when you buy four. Now just have to worry if all the hardware might need replaced. Thanks for your time!
Nov 18, 2009 at 1:37 PM
OBXAUTOMEDIC
  • 3,711 POSTS
No problem, thats what we are here for...
Good Luck
Nov 20, 2009 at 1:18 PM
