1996 Chrysler Intrepid
DIBBS
Noises problem
1996 Chrysler Intrepid 6 cyl Front Wheel Drive Automatic
hi i have a 96 intrepid and at speeds of 60k or more there is a short clunk up front and then car runs ok. and then it does it again
the codes come up as 14 21 33 43
thanks gary
Aug 25, 2009 at 2:22 AM
  • 110,248 POSTS
•14* MAP sensor voltage below .16V or over 4.96V
•21 Oxygen sensor signal doesn't change (stays at 4.3-4.5V). Probably bad oxygen sensor
•23* Incoming air temperature sensor
may be bad
•33 Air conditioning clutch relay circuit open or shorted
•43 Peak primary coil current not achieved with max dwell time
OR
•43 Cylinder misfire
OR
•43 Problem in power module to logic module
interface
Okay, now where do we start. Does it feel like the engine misfires when you hear the noise? Does it do it all of the time or under specific conditions?
Oct 9, 2009 at 9:47 AM
