1994 Chrysler Intrepid Cooling system
1994 CHRYSLER INTREPID
285,000 MILES • 6 CYL • 2WD • AUTOMATIC
TWISTSIS
I have replaced the thermostat and the heat sensor, there doesn't appear to be a leak but the car keeps overheating. especially after idling in a drive through.
Should I replace the fan clutch or the whole fan?
Has anyone else been having this problem?
Aug 31, 2009 at 4:33 AM
Could be a clogged-up radiator or water pump defective, air in the system if not get it block and pressure tested.
Aug 31, 2009 at 8:13 AM
