do you know where the compressors are located and does it have a fuse and where that might be located. thank-you
Mar 16, 2008 at 12:34 AM
MERLIN2021
✓Experienced Mechanic
The compressor is under the right rear quarter panel, check for fuses in the in car and underhood fuse blocks...use a test light at the connector, you may have power, but a bad compressor!
