1992 Chrysler Imperial rear suspension
1992 CHRYSLER IMPERIAL
105,005 MILES • 6 CYL • FWD • AUTOMATIC
PETER PHILBRICK
do you know where the compressors are located and does it have a fuse and where that might be located. thank-you
Mar 16, 2008 at 12:34 AM
MERLIN2021
  • 17,250 POSTS
The compressor is under the right rear quarter panel, check for fuses in the in car and underhood fuse blocks...use a test light at the connector, you may have power, but a bad compressor!
Mar 16, 2008 at 12:53 AM
