1992 Chrysler Imperial alarm
1992 CHRYSLER IMPERIAL
200,000 MILES • 6 CYL • 2WD • AUTOMATIC
BIG JOE44444444
The alarm went off for know reason,it stoped sounding off about 2 hours but now the car will not crank,it just turns over.what to do?
wife at home pregnet no car
Mar 5, 2010 at 4:32 AM
CARADIODOC
  • 34,381 POSTS
"Crank" and "turn over" are the same thing. I assume you mean it doesn't start and run. Use the key to unlock the door. That turns the alarm off. If that doesn't work, suspect a broken wire between the door hinges or the switch is broken or disconnected from the lock cylinder. Unlocking the passenger door will also turn the alarm off.
caradiodoc
Mar 8, 2010 at 4:14 PM
