Electrical problem
1991 Chrysler Imperial 6 cyl Front Wheel Drive Automatic 78k miles
About a week ago now I installed an afermarket stereo into my car and later that night I was pulled over and cited for my running lights not working.(However brakes and turn signals still work) I thought it was just a loose connection under my dash from doing the work. I tore apart my dash and found no loose connections, I also checked the fuse box in my glove compartment and the one under my hood and found no bad fuses. I assume it's not a burned out bulb since the turn signals and brake lamps still work. Any insight to what may be causing my lights to quit working would be greatly appreciated.
Jun 1, 2010 at 10:21 AM
