1991 Chrysler Imperial computer
190,000 MILES • 6 CYL • FWD • AUTOMATIC
ROBERT ZEPEDA
do u know the relearn procedures for the computer? I installed a new brain for my chrysler cause i had no spark to my plugs im sure this is the problem but the car still wont start...it said i may have to do a relearn procedure but i dont know what the procedures are....
Oct 16, 2008 at 7:14 AM
  • 110,248 POSTS
For the computer to relearn, the car needs to start. After starting, the check engine light will flash for about 10 seconds. During this time, the computer is doing its job. After that time, the light should stop and go out. If it doesn't, you need to have the computer reset.
If you are getting no power to the coil, recheck your connections. Make sure all wires are tight, and make sure the wiring harness at the computer is tight.
Mar 16, 2009 at 3:02 PM
