voyager floods while driving
CHRYSLER GRAND VOYAGER
CARAVAN
I have an 87 voyager 3l v6 I just changed brain box and put in plugs , dist. cap , rotor and I took out the oxy sensor and cleaned it .I keep getting this flooding or starving while I'm driving ,but runs great in the mean time , then it stalls and I can't start it again for quite sometime after. I'm getting P.Oed at this cause I can't even drive 10 mi without it leaving me stranded on the side of the road . Anyone Please help me The only code I keep getting is 22 which is coolant sensor voltage too low or too high
Feb 9, 2006 at 11:44 AM
CHEVY350GUY
  • 109 POSTS
go to the source of the code. test the sensor, then follow the wires to see if you have a short in the circuit. the temp sensor can make you run too rich or lean, and make hard starts.
Feb 9, 2006 at 11:59 AM
