1996 Plymouth Grand Voyager Stuck in 2nd
BECKYN
I just recenlty bought a 1996 Plymouth Grand Voyager SE, and I am having a problem with the transmission. Every so often, the van will change gears fine then it will get to 2nd gear and get stuck, then you have to turn off the van and restart it to reset it and it will do fine for a while then it will do it again. What can cause this and how can it be fixed, or is there a way to reset it and it not do it anymore? Please help!!
Oct 20, 2007 at 2:17 PM
SERVICE WRITER
  • 9,123 POSTS
Your best bet is to have the codes read to start with. The transmission is going into limp ode. meaning it will get you out of a bind, but needs to be fixed. Maybe a a bad speed sensor, TCM off the top of my head.
Make a point to check the air filter on this one as they are often neglected due to the difficulty geting to them.
Oct 20, 2007 at 2:29 PM
Suggested Repair
Have the transmission codes read first. The transmission is entering limp mode; possible causes include a bad speed sensor or TCM. Also check the air filter, which is often neglected.
Conversation Summary
The owner of a 1996 Plymouth Grand Voyager says it sometimes shifts normally, then sticks in second until the van is shut off and restarted. The expert says the transmission is entering limp mode and recommends reading codes first, mentioning a possible bad speed sensor or TCM, and also checking the air filter.
