It is allways the same. Driving over 45 miles My wipers go on one time just before the trannyl suddenly downshift to 2nd gear and does not go any higher. When I you pull over, put it in park, kill the engine, and then re-start it, it works fine for another two o three days. I did a computer scan and I got a transmission relay code, I don't even know where that relay is or if can be a problem in the circuit some where before or after the relay.
At least with the wiper thing I get a warning before happens so I can slow down
