1990 Plymouth Grand Voyager Alternator Removal Fix
GARY D C
1990 plymouth grand voyager 205,912 mi v6 i have disconnected the alternator wiring and disconnected the alternator from the mount but can not get the alternator out from the top [mountting braket in the way] or out from the bottom [exhaust in the way] how do i get it out? :?
Jul 29, 2007 at 10:23 AM
LEGITIMATE007
  • 5,121 POSTS
[quote:0554edc47e="gary d c"]1990 plymouth grand voyager 205,912 mi v6 i have disconnected the alternator wiring and disconnected the alternator from the mount but can not get the alternator out from the top [mountting braket in the way] or out from the bottom [exhaust in the way] how do i get it out? :?[/quote:0554edc47e]
it can be done from the top but you have to remove the bracket, yes it is tedious and time consuming. but ive done it three times . twice from the top and once from the bottom. the one time that i did it from the bottom, I had it on a lift and did not have to remove the exhaust. mine is a 3.3. I think a 3.0 might be a little easier though. good luck
Dec 23, 2007 at 3:57 AM
Suggested Repair
Remove the mounting bracket and extract the alternator from the top. It can also be removed from the bottom on a lift without removing the exhaust.
Conversation Summary
The owner of a 1990 Plymouth Grand Voyager V6 has disconnected the alternator wiring and mounts but cannot remove the unit because the mounting bracket blocks the top and the exhaust blocks the bottom. The expert says to remove the bracket and take the alternator out from the top, noting that the job is tedious but possible. The expert has also removed one from the bottom on a lift without removing the exhaust.
