CRONK
I have a 1996 plymouth voyager,3.3 ltr. with around 2ook km on it.The check engine light came on and I put a code reader on it and it came up as " lean fuel".
After running some injector cleaner thru the system the code was still there.I took the van to a garage , they said it was the fuel pump,after changing the pump,still the same thing.So they changed the cam sensor, crank sensor,etc.After paying my 1000$ bill I was driving home and the check engine light came back on!It now runs worse than it did before, also we now have to crank the engine over ,stop and repeat this several times before the engine will fire.
Any suggestions would be greatly appreciated.
Jeff
Feb 14, 2007 at 12:52 AM
MATHIASO
  • 1,209 POSTS
Inspect intake manifold for vacuum leak, ait induction system. it's may be unmetered air drawn into the engine behind the airflow meter.
Feb 14, 2007 at 1:45 AM
  • 75,988 POSTS
You probably made things worst with the cleaner. When was the last time the O2 sensor was replaced.
Could be false air/low fuel pressure.
Feb 14, 2007 at 7:39 AM
MATHIASO
  • 1,209 POSTS
rasmataz, happy valentine day. :wink:
Feb 15, 2007 at 2:32 AM
  • 75,988 POSTS
Happy Valentines Day to you too! my friend.
Feb 15, 2007 at 5:51 AM
