Cooling fan inop
CHRYSLER GRAND VOYAGER
RC_VIPER
I have a 2003 jeep grand cherokee. The cooling fan came on and stayed on after the car was shut off. Now the fan does not work at all. If i put power to the fan it does work. There is no power at the fan plug by the radiator with the temp at 230. The fuse is good and all the relays that i could find were good.
Thanks
Feb 12, 2007 at 9:01 PM
  • CAR REPAIR CONTRIBUTOR
itch.
Does it have a temperature switch, also could be a
coolant temperature sensor or the PCM
Feb 13, 2007 at 4:12 AM
RC_VIPER
Thanks for the help. It was the cooling fan relay that was bad. It took some time to find it as they hide it behind the right side headlight.
Feb 19, 2007 at 8:47 PM
