2006 Chrysler Grand Voyager Car lights and gauges flicker
2006 CHRYSLER GRAND VOYAGER
CANUVTUNA
Electrical problem
2006 Chrysler Grand Voyager 6 cyl Two Wheel Drive Automatic
I don't know if it's the battery or alternator.My car won't start unless jumped and won't stay on if idled more then 10 min.
Jan 29, 2010 at 10:21 AM
CARADIODOC
  • 34,381 POSTS
How many miles??? Does the Check Engine light come on? Does the Battery light come on?
After charging the battery at a low rate for half an hour, remove the charger, then measure the voltage across the two posts with a cheap digital voltmeter. A fully charged battery will read around 12.6 volts. If you find closer to 11.0 volts or less, there's a shorted cell in the battery.
If the voltage is around 12.6, measure again with the engine running. It must be between 13.75 and 14.75. If it is low, holler back; we'll need to make some measurements on the two small wires on the back of the alternator while the engine is running.
caradiodoc
Feb 24, 2010 at 11:11 PM
