2004 Chrysler Grand Voyager will not fire
180,000 MILES • 6 CYL • FWD • AUTOMATIC
SEAN D'SENA
my wife was driving her chrysler grand voyager when it stoped and has not been able to start since it has fuel cranks but will not fire can you give me a few ideas on where to start
May 11, 2010 at 11:16 PM
LEGITIMATE007
  • 5,121 POSTS
if this is distributorless i would start with the coil pack and the harnass that connects it, then the crank position sensor, also check to see if it will start in neutral. could be a neutral safety switch either way, but if it has a distributor, start with the coil then cap and rotor
May 15, 2010 at 8:02 AM
