2002 Chrysler Minivan headlamp malfunction
RSEDLOCK
I have a Chrysler Voyager e minivan. The driver side low-beam headlamp is out. the High beam on that side, and the passenger side low beam and high beam work. I replaced the bulb and it still does not work.
I cannot locate a fuse or a breaker that controls this. Any suggestions as to how to troubleshoot and fix the problem?
Thanks,
Ray
Jan 4, 2006 at 6:18 AM
  • 55,682 POSTS
Check the headlight control switch
Jan 4, 2006 at 6:44 AM
RSEDLOCK
Does the switch send a different signal to each low beam light? The other lights work.
Thanks,
Ray
Jan 4, 2006 at 6:46 AM
