2002 Chrysler Grand Voyager Instrument Panel problem
68,575 MILES • 6 CYL • FWD • AUTOMATIC
CYBRSPIDEY
My instrument panel lights went out. All my gauges still work though. Also, I believe there are suppose to be lights behind my A/C controls, and they are also out. The odometer still is illuminated and when you use the dimmer switch, will lighten or darken accordingly. I can't seem to find a fuse to check for this or a solution online. Again, ALL the gauges are working properly, just the lights went out and haven't come back on.
Feb 9, 2009 at 12:05 PM
CYBRSPIDEY
Ok. I found the solution. Disconnect the battery and wait a few minutes. This resets the fuses. Plugged battery back in, Bam, now I have instrument panel lights.
[quote:7137040638="cybrspidey"]Electrical problem
2002 Chrysler Grand Voyager 6 cyl Front Wheel Drive Automatic 68575 miles
My instrument panel lights went out. All my gauges still work though. Also, I believe there are suppose to be lights behind my A/C controls, and they are also out. The odometer still is illuminated and when you use the dimmer switch, will lighten or darken accordingly. I can't seem to find a fuse to check for this or a solution online. Again, ALL the gauges are working properly, just the lights went out and haven't come back on.[/quote:7137040638]
Feb 9, 2009 at 12:32 PM
