2001 Chysler Grand Voyager windshield washer
2001 CHRYSLER GRAND VOYAGER
CYANNOS
Other Category problem
2001 Chysler Grand Voyager V6 Front Wheel Drive Automatic 120000 miles
My windshield washer just stopped working this moringing on my drive to work. It worked when I started but halfway to work it stopped. I thought I was out of fluid but after filling it up I hear the pump motor working but no fluid is being sprayed on the windshield. Any suggestions
Dec 4, 2007 at 12:57 AM
LEGITIMATE007
  • 5,121 POSTS
one of the little tubings coming off of the washer motor or connecting to the wipers may be clogged or have come unhooked. trace the tubing and make sure everything is hooked up. You said the motor is still running when u press the button for fluid?
Mar 2, 2008 at 2:06 AM
CYANNOS
[quote:73fcf0278f="legitimate007"]one of the little tubings coming off of the washer motor or connecting to the wipers may be clogged or have come unhooked. trace the tubing and make sure everything is hooked up. You said the motor is still running when u press the button for fluid?[/quote:73fcf0278f]
I don't know what happened but when I got back in the van after work and tried the wipers the washer was working fine. Maybe it was air in the hose. Thanks for the reply
Mar 4, 2008 at 4:20 AM
LEGITIMATE007
  • 5,121 POSTS
your quite welcome glad everything worked out
Mar 4, 2008 at 6:42 PM
