2001 Chrysler Grand Voyager noise from front end
70,000 MILES • 6 CYL • 2WD • AUTOMATIC
HANGMAN
  • 8 POSTS
My van keeps making a rubbing grinding grinding type of noise in the front end it seems to drive and steer fine, I took it to a shop and the mechanic said it was just the rack and pinon steering he said this was normal for this van he assured me everything was fine and safe, he said I would be wasting my money to replace it because in about a year it would be doing it again does this sound right?
Sep 29, 2008 at 1:12 AM
  • 110,248 POSTS
Hi:
I have to be honest, I never heard a rack make a grinding noise. Is the sound only when you turn the wheel? I need to know that so I can help you. To me it could be a brake problem, backing plate rubbing, sway bar bushings...
PS: Does the steering feel normal?
Oct 7, 2008 at 2:23 PM
HANGMAN
  • 8 POSTS
steering feels fine, also makes noise when you hit a bump or pot hole not just when turning
Oct 12, 2008 at 3:42 PM
  • 110,248 POSTS
Hi:
The noise when you hit a bump could be strut plates, stabalizer links... I think you should have a second opinion on the grinding.
Oct 13, 2008 at 12:13 AM
