2000 Chysler Grand Voyager Grand Voyager Electrical Problem
KEN NEELY
Electrical problem
2000 Chysler Grand Voyager V6 Two Wheel Drive Automatic 121000 miles
First, the air bag light started to come on, usually when the vehical was being turned. It makes a bell sound when it turns on. After the light is on for a while, it goes off. Next, the horn stopped working. Now the cruise control doesn't work. Any ideas on the problem(s) would be most appreciated. Thanks. Ken
Dec 3, 2007 at 2:43 PM
ZUE
  • 76 POSTS
I recommend removing the steering wheel cover and performing a visual inspection of the wiring and plug attachment. Everything you mentioned is centric to the steering wheel hub assembly.
Dec 3, 2007 at 3:06 PM
ZUE
  • 76 POSTS
Did you find a solution to your earlier problem?
Dec 4, 2010 at 10:53 PM
