2000 Chysler Grand Voyager Engine stops
BRUCE84
Engine problem
2000 Chysler Grand Voyager Engine Size unknown Two Wheel Drive Automatic 76890 miles
When i drive my voyager as the engine slows right down, the engine just cuts out! This problem does not happen all of the time! The engine starts up straight away! I have just taken it to my local garage, he has cleaned the fuel filter out! but the problem is still there.Please could you advise me what i can do.
Thanks
Bruce
Jan 2, 2008 at 12:58 AM
LEGITIMATE007
  • 5,121 POSTS
I never new you could clean the fuel filter out but I dont' know everything either. Anyway check your air filter and make sure its clean and replace if necessary. Also have your air idle control valve cleaned ,tested and replaced if necessary and let me know what happens.
Mar 2, 2008 at 2:08 AM
