2000 Chrysler Grand Voyager no speedometer,full gauage, no
2000 CHRYSLER GRAND VOYAGER
JASONJ70
  • 13 POSTS
2000 Chrysler Grand Voyager 6 cyl
all my gauges on the cluster (speedometer, tach, fuel gauage, temp gauage, odemeter, and shift information) is gone. My abs light, service engine soon and air bag light are lite too. when it put on the computer it states that everything is good right. Can you help with this?
Oct 24, 2009 at 4:51 AM
DOCFIXIT
  • 18,828 POSTS
Hi
Have you checked fuse # 28 a 10 amp in underhood Power Distribution Center?
Let me know
Thanks for donate
Oct 24, 2009 at 6:23 AM
JASONJ70
  • 13 POSTS
all the fuses have been checked.
Oct 24, 2009 at 6:50 AM
DOCFIXIT
  • 18,828 POSTS
Well then it's time to pull instrument panel out and test for voltage, grounds and printed cicuit board contiuity. Is this something your up to ? If so do you have test light And digital volt ohm meter?
Oct 24, 2009 at 7:00 AM
JASONJ70
  • 13 POSTS
There is power and ground at the plug that plugs into the instrument panel.
Oct 27, 2009 at 1:53 AM
DOCFIXIT
  • 18,828 POSTS
Check these terminals
#2- pink-voltage
#6- orange- voltage
#7- black/light green- ground
#9- white/black- ground
#10- violet/brown- voltage
#11- red/white- voltage
#13- black- ground
test key on
Oct 27, 2009 at 2:11 AM
JASONJ70
  • 13 POSTS
we took the speedo cluster out of this van and put in it a identical van and that works in there prefectly. took bcm from the broken van and put in the other van and it work prefect in there also. we took the main computerfrom the broken van and put in the other van and it worked good in there. took other body module under hood on right side of van, put in the good van and it worked fine in there, too.
there is no diagram for the fuses under dash. where do we get something like that? the plug in up there as good grounds and powers are fine at that plugin. HELP!!!! I WANT MY VAN BACK!!!!!!
Oct 27, 2009 at 11:55 PM
DOCFIXIT
  • 18,828 POSTS
Are fuses numbered? if yes pull out check #24
Oct 28, 2009 at 3:46 AM
JASONJ70
  • 13 POSTS
I don't know if this would matter, but I just had the torquec converter replaced before this happened would that have anything to do with the problem?
Oct 28, 2009 at 5:04 AM
JASONJ70
  • 13 POSTS
where is this #24 located at under dash or under hood?
Oct 28, 2009 at 6:17 AM
DOCFIXIT
  • 18,828 POSTS
https://images.2carpros.com/forum/automotive_pictures/198357_Graphic_221.jpg
well it copied to small on bottom left second up in verticle position
Oct 28, 2009 at 6:36 AM
JASONJ70
  • 13 POSTS
where is this fuses box located there are 2 of them. I could not see the diagram well enough too small.
is there somewhere we can see a bigger diagram?
Oct 28, 2009 at 7:09 AM
DOCFIXIT
  • 18,828 POSTS
https://images.2carpros.com/forum/automotive_pictures/198357_Graphic_222.jpg
Oct 28, 2009 at 7:21 AM
JASONJ70
  • 13 POSTS
all the fuses in the fuse box are good. tested them with a test lite. could it be a relay?
Oct 28, 2009 at 7:47 AM
DOCFIXIT
  • 18,828 POSTS
Having trouble locating another fuse box. There is one under instrument panel?
Seems a change was made in model year what is production date?
Oct 28, 2009 at 7:55 AM
JASONJ70
  • 13 POSTS
the production date is 4/99
Oct 28, 2009 at 8:57 AM
JASONJ70
  • 13 POSTS
I have had the fly wheel replaced also.
Oct 28, 2009 at 11:30 PM
DOCFIXIT
  • 18,828 POSTS
In junction panel under left side dash check fuse #2 a 10 amp. Is PRNDL light out?
Oct 29, 2009 at 5:17 AM
JASONJ70
  • 13 POSTS
Yes the lite is out and the odemeter is too.
Oct 30, 2009 at 12:13 AM
JASONJ70
  • 13 POSTS
ALL THE FUSES ARE GOOD IN BOTH FUSE BOXES; UNDER THE DASH AND UNDER THE HOOD ON THE LEFT HAND SIDE.
Oct 30, 2009 at 5:05 AM
JASONJ70
  • 13 POSTS
no gauages work, the heater is stuck in defrost mode, no buttons work, on the heater panel.
Nov 1, 2009 at 11:08 PM
