1999 Chysler Grand Voyager water pump?
ESSJAY1976
Engine Cooling problem
1999 Chysler Grand Voyager 6 cyl All Wheel Drive Manual 100k miles
i hjave a chrysler grand vpyager uk model v plate 99 diesal, i started losing antifreeze coolant from the underside of engine after long drives, now the fan comes on the the temperature guage is rising,
coud this be a hose or is iot the water pump? is there any way of telling. If this is the pump please can you supply directions to change the unit
many thanks
sarah jane
Jul 7, 2008 at 3:56 AM
  • 110,248 POSTS
Hi Sarah Jane:
Well, to determine if it is the pump or a hose, you will need to get under the vehicle. Try to dry the underside off so you can get a better look at where it may be coming from. Next, locate the waterpump. The under side of the pump has a weap hole that will leak if the bearing / seal is bad. Check there for stains / coolant.
If it is dry, then you will need to continue your search. Check coolant lines and the radiator.
Let me know if it's the pump. I'll try to get you the directions.
Oct 8, 2008 at 6:46 AM
