1999 Chrysler Grand Voyager Changing Front Brake Pads
1999 CHRYSLER GRAND VOYAGER
134,000 MILES • 6 CYL • 2WD • AUTOMATIC
HARRYWESTON
Hi can any tell me if i need to bleed the front brakes to release the brake callipers.
Do i need any special tools to change the brake pads.
This is a new car for me an i have never worked on a Crysler, eevryone i talk to states they are hard to work on and you need special tools, I took the front wheel off and they dont look to complicated, but i alway like to urge with causion first.
Oct 1, 2010 at 11:44 AM
BLACKOP555
  • 10,386 POSTS
no worries at all. you will need a larger c clamp and some sockets and wrenches to get caliper off.
once caliper is off compress c clamp on the caliper till the piston is all way in caliper.
put on new pads pump up brakes if brake pedal is hard your good to go.
Oct 2, 2010 at 6:46 AM
