1998 Chrysler Grand Voyager not heating up
159,000 MILES • 6 CYL • FWD • AUTOMATIC
SOCCERDAD254
the heater stopped heating up the cabin it used to have a good heater.I replaced the thermostate this summer and the radiator cap. it is not laeking from the heater core.
Dec 12, 2009 at 3:42 AM
CARADIODOC
  • 34,413 POSTS
Is the problem cold air or no air flow?
If the thermostat were sticking open, the temperature gauge would also stay on cold. A radiator cap that doesn't maintain pressure could lead to an overheating condition. If the only symptom is cold air from the heater, suspect a plugged heater core. After the engine is warmed up, feel the two heater hoses. They should be too hot to hold onto for very long. If they're cool, the heater core should be back-flushed until water flows freely. If the hoses are hot, suspect a problem with the computer controls or an actuator motor.
caradiodoc
Dec 23, 2009 at 2:12 PM
