1998 Chrysler Grand Voyager engine stall
13,200 MILES • 6 CYL • FWD • AUTOMATIC
CMOSS1
I have a 1998 Grand Voyager, Here is the problem
It stalled when I was slowing down coming of the interstate, my fuel gage went to E my tach gage went to 0 and my MPH gage went to 120 and then the van stalled. I put it in park and it started back up and all the gages went back to normal. It has stalled 2 other times but it just stalled, both times it stalled i was slowing down. I have been thinking it might be the EGR valve, is this a good starting point?
Thanks,
Jan 6, 2009 at 7:44 AM
VIPERTEK
  • 40 POSTS
An EGR is a possible,other common problems are ais motor(idle speed motor) GM calls them iac's. throttle body should be cleaned at same time. ais is located in the throttle body. It is also possible that either egr or ais will not throw a check eng lite.
Jan 9, 2009 at 9:49 AM
